Steering Play
- Thread starter colin944
colin944
colin944
Why are you never about when I have a question ? [ORIGINAL: Indi9xx You can have the steering rack re-manufactured.. or get a used rack..
Indi9xx
Kongsodoken
ChasR
Kongsodoken
Recon racks seem to be £200 to £250 ....I brought a brand new ZF rack from the UK agents for £300 deliveredORIGINAL: ChasR IMO there are reconditioned steering racks and there are reconditioned racks. On an old modern I found this to be the case (the new rack lasted 14 months before it became notchy) and in the Stag world it is a known issue (a rack I acquired secondhand which leaked more than the Exxon Valdez was actually tighter than the one I fitted; Speaking to others it is a bit of a lottery as to how good a steering rack you get). I'd be tempted to go used or a ZF recon item in your shoes.
Kongsodoken
ChasR
Ah, fair enough, I thought that may have been for a reconditioned rack via a certain reconditioning place within the Midlands. Stag steering racks are not that much cheaper new (around £140-200) and after often iffyORIGINAL: KongsodokenRecon racks seem to be £200 to £250 ....I brought a brand new ZF rack from the UK agents for £300 deliveredORIGINAL: ChasR IMO there are reconditioned steering racks and there are reconditioned racks. On an old modern I found this to be the case (the new rack lasted 14 months before it became notchy) and in the Stag world it is a known issue (a rack I acquired secondhand which leaked more than the Exxon Valdez was actually tighter than the one I fitted; Speaking to others it is a bit of a lottery as to how good a steering rack you get). I'd be tempted to go used or a ZF recon item in your shoes.
