Have just had front tyres renewed (Pirellis). Tyre Fitter had latest laser tracking alignment rig and a check was free so had the car checked. I knew there was some problem as the front O/S tyre was wearing on the inside edge. The alignment check showed that the front O/S wheel camber was slightly out of tolerance as was the tracking on both fronts. Problem - If I have the tracking adjusted (which I need to) the tyre place does not have a PS2 to recalibrate the steering sensor. As I live in the depths of Cornwall the nearest OPC at Exeter is some distance away.
How much of an issue is the steering sensor within the PSM. The car is only used for road driving and not tracked. Will it make that much difference to everyday use?
All advice appreciated
