Steering Shaft refittment
- Thread starter chrisg
As Scott said you need to loosen the steering rack off so you can get enough room to pop the UJ over the spindle. Also the spindles on the rack and upper steering column have a flat on one edge which needs to be lined up with the flat in the UJ, IIRC. Also make sure you use new pinch bolts when you refit it as I reused the old ones on mine and they came loose pretty quick, thats why there are flats on the spindles in case the pinch bolt fails you don't loose the steering
Well best of luck, make sure its all nice and tight afterwards.
Dave K.
chrisg
As a result I'm worried I might have upset the alignment/ bent the steering rack ? I'll try undoing the rack from the cross member and see how I get on with a fresh approach.
C
