steering squeak
- Thread starter aps153
If they've not been replaced recently it's possible that the noise is coming from the strut top mounts (they dry out with time). As a temporary cure you could try squirting some washing-up liquid in the area to provide some lubrication. If that works then you'll know that they need replacing and if not then you'll need to look elsewhere; the steering and lower control arm joints most probably.
Jeff
It is the back of the steering wheel j u s t rubbing on the indicator stalk cover, plastic to plastic so very faint, but even my aged hearing can hear it...
just a thought anyway.
