I have a low speed knock that I can feel through the steering wheel, but only in two places. There is also some vagueness in the steering nothing major, but it's there at speed.
Today why looking for a small oil leak I noticed how close the steering shaft is to the exhaust (I'd guess at around 5mm so probably a good chance the engine mounts need replacing),but while I was there I thought I would check for play in the steering uj.I could move the lower part of the uj left to right, not rotational but play across the pin. I'm guessing this isn't normal? Would also tie up with the clonks in two places.
I haven't checked rotational play as I didn't have an assistant to hand to work the steering wheel!!
