Steering Wheel Change
jeremyh
Hi
Does anybody know if you can swop the older style non airbag steering wheel from a 1991 Turbo to the later type wheel with airbag from a 1993 turbo.
I have found one on ebay but I want to be sure I can swop them over before buying as it is £150.
Jeremy
If memory serves me right the horn push does just pull out,hopefully somebody will confirm this for you.It's just undoing the nut on the splined shaft and pulling the wheel off then,the wheel was quite tight on mine and took some serious clouts to get it off,leave the nut on a few threads so the wheel can't come off in your face.
Assuming it is the standard type, yes the horn pad just pulls off - 3 locating lugs- lower corners and top centre - watch out for the wire for the horn it can be damaged if it comes off to far.
Then as Gazzy says big, can be very tight, nut - 24 mm IIRC and pull as he says.
Here are some tips on changing the wheel:
http://www.porscheclubgbforum.com/tm.asp?m=317525&mpage=1&key=steering%2Cwheel&#317525
