Steering Wheel Movement
- Thread starter jeegnesh
JCB..
Non-member
ORIGINAL: sja
There are a few recent posts about this icluding one form me. Look like its a "feature" not a fault!
Try balance tyres, I did but not any real improvement.
It's certainly not a feature!
If your car is 'right' it should be rock steady right up to top speed.
Underbody aerodynamic fixings
Tyres
Alignment
Worn Suspension.
Check them all.
SteveW14
When I had a similar issues it was down to tyres, but this was fairly obvious on mine as it was the only thing that had changed around the time the problem started. If yours are okay and this has just started then not likely to be that.
As getting the tyres balanced is the cheapest place to start I would go with this and then work your way through the other options, a suspension geometry check and adjustment will set you back about 200.
Hope you manage to get it sorted.
A standard tracking check like you'd get at Kwik Fit would point out anyting obvious, (although it's out you'll probably notice excessive wera on the inner/outer edges of the tyres), but a full 4 wheel alignment is recommended as there are a lot of adjustments possible on the Boxster for both front and rear wheels.
jeegnesh
If you going in a straight line anf take your hands of the steering (on a smooth road) if the car pulls left or right, its a tracking problem.
In my case I think a got a little of both. Need to get the wheels tracked and balanced.
