Steering wheel removal tips...
- Thread starter Guest
As recommended disconnect battery
Straighten wheel and with wheel straight ahead tippex a mark at 12 o'clock on the spline after you have removed the nut.. This way if during removal the spline moves you can realign the wheel easily to straight ahead.
It does need a good pull.
mike
Jacob
The wheel nut takes a bit of effort to get off, as does the wheel once the nut is removed. Remember to take Mikes advice and use a bit of tippex to help you align the steering wheel when putting it back on.
Are you putting an aftermarket steering wheel on?
And yes i am fitting a nardi wheel c/w boss kit.
Cheers Db
pae
Also, IIRC it's a 24mm socket, not 27? Can't be certain, but I thought it was 27 when I first tried and it was 24mm (but I may be wrong, and I am talking about a 924S [&:] )
hope that helps, Phil
