Steering wheel removal
Gimme Shelter
I intend to replace the steering wheel on my 1990 C4 (with a Momo Prototipo, since you ask). How do I remove the existing standard one? Any help appreciated. Thanks.
Hi GS You could download this steering wheel guide... I can't remember where I found it but may be useful to you... https://dl.dropbox.com/u/2495363/Steering%20Wheel%20upgrade.pdf
Also, to avoid breaking your nose/face: After loosening the centre nut, leave it screwed onto the shaft a couple of turns then pull the steering wheel towards you to dislodge it. Then remove the nut and steering wheel with all your teeth intact. [:D]
Thanks, guys. Rather as I suspected, but I hadn't dared pull hard enough on the rectangular "horn button", obviously.
Thought you might like a picture of the new wheel.
ORIGINAL: Gimme Shelter Thought you might like a picture of the new wheel.
That is what a C2 wheel (before the airbag era) should have looked like. I never understood the ugly original wheels. Looks good! (What about the teeth?)
ORIGINAL: gregmarshall Hi GS You could download this steering wheel guide... I can't remember where I found it but may be useful to you... https://dl.dropbox.com/u/2495363/Steering%20Wheel%20upgrade.pdf
OK, who thought it was a good idea to borrow my work.........Not impressed with whoever did this. http://www.964kevin.homecall.co.uk/ Kevin
