chrisg
Dear All
I recently picked up the car from the garage having had a gearbox rebuild, driveshaft uj's and rear wheel bearings replaced.
Yesterday whilst in traffic after ~ 300 miles on the rebuild the clutch pedal starting sticking at it's further point i.e. when fully depressed it doesn't spring back quickly and sometimes needs assistance.
1600 miles ago the clutch was replaced whilst the engine was out:
Refaced flywheel, new clutch, bearings in the clutch fork etc.
I later then ~1000 miles ago replaced both clutch cylinders as I had the classic clutch on the floor leaking cylinder - it turned out to be the master cylinder seals that had gone.
I'm going to check the bellhousing and slave cylinder bolts for tension at the weekend.
Any other suggestions as to what could be causing the pedal to catch/stick gratefully received ?
