944_85
I have a problem with sticky gear shifts, on my 1985 oval dash 944.
When cold there is no problem shifting in or out of gear. However when very warm, sometimes I struggle to take it out of gear. This mostly happens when in 2nd, and I have had it a few times with 3rd. Still no problem getting into gear, only taking it out.
I already tried a few things but not much improvement:
1) replace gearbox oil to new mineral GL4 oil
2) replace gearbox oil to new synthetic GL4 oil
3) adjust pedal play
4) check and adjust clutch slave cylinder to max. 18mm movement
5) adjust gear stick alignment at top of gearbox
6) replace brake fluid and bleed
I am starting to thing that it must be inside the gearbox, however I hope not.
Not sure if this can be a factor, but the clutch rubber center is on it's way out. Which cause a bit of shudder when the car is very very hot.
Any ideas what can cause this sticky gears?
