Sticky Revs...
- Thread starter arumdevil
peanut
George Elliott
George
944t
964
arumdevil
Peanut, I will check again but from memory I don't think it's the cable as it happens if I rev the throttle by hand in the engine bay - I can see the throttle is back in it's 'home' position but the engine still takes a while to catch up.
Tony, I ordered the part from OPC Exeter yesterday, they said it will be with me mid next week...
George, thanks for that tip, definitely worth checking - I had a similar problem on my Saab 900T and after giving that a clean it was better. The idle on the 944 isn't ideal (!) it is normally at or just above 1000rpm, never below. Also, (very) occasionally (and not since I bunged that hole mentioned) the engine would gradually rev itself up to around 2500rpm while I was supposedly idling.
Anyway, the idle valve sounds like a good place to start, along with a more thorough boost leak hunt.
Will report back later (possibly much later as I feel awful and flu-ey).
Arum
George Elliott
good luck
George
944t
