Got a weird issue with my Turbo's brake pedal....
You know if you pump the brakes or the clutch when the engine is off then the pedals go stiff because they are hydraulically assisted? Well I am getting the same thing when I drive along - typically just after changing gear. The brakes work just fine still but I also notice that when I depress the brake pedal, the clutch pedal goes down a little too, and I can feel shuddering in both pedals as I do so. This is under very light braking, so nothing to do with ABS or the physical brakes themselves.
The really weird thing is that this behavour disappears if you sit on the motorway in 6th for a few mins then it goes back to normal, or if you brake after pushing the clutch fully in. Drive off the motorway onto a slip-road and after changing gear, the stiff brake will be back again. Note there is no such stiffness with the clutch pedal.
I popped into see Chris F at CG yesterday and we could hear a squeek when the clutch was depressed coming from the slave clutch cylinder at the back of the car. So as the clutch and brake use the same hydraulic system he thought that this may be the cause.
I have booked into my OPC for next Mon but wondered if anyone else had come across such a thing before?
