[font="arial,helvetica,sans-serif"]Many years ago I repainted cars, so I have lots of experience respraying, blending and touching up all types of dent and blemishes.[/font]
[font="arial,helvetica,sans-serif"]Whilst there are many kits available some with a base colour and some with a top coat, the application principal is similar.[/font]
[font="arial,helvetica,sans-serif"] [/font]
[font="arial,helvetica,sans-serif"]Remember...the finish gets better with time, so no need to rush.[/font]
[ul][*][font="arial,helvetica,sans-serif"]Get the right toolsIf the chip is jagged, lightly rub down the edges, don't go mad.Degrease all areas well.[/font][ul][*]Small diameter implement (ear bud size), extremely fine grade paper - similar to craft drill sanding tips. Try to glue sand paper to earbud, whatever works for you.[/ul][*][font="arial,helvetica,sans-serif"]Now the paint[/font][ul][*]Cut the head off an ear bud at both ends.[*]Place the straw like implement in to the paint and then put your finger over the top to hold the paint in. Lift out, wipe excess.[*]Place the paint tip over the chip and release finger, allow the paint to fill the chip.[/ul][*][font="arial,helvetica,sans-serif"]Leave the paint 20 minutes[/font][ul][*]You want the paint to be mushroom shaped for a single application paint kit.[*]and indented for a two paint kit.[ul][*]after 20 mins add the top coat ( two pack kit only) so that the final coat is mushroom shaped (leave 20 mins).[/ul][/ul][*][font="arial,helvetica,sans-serif"]You should have a Mushroom paint finish, i.e. higher paint/lacquer than the original finish. Now we need to level it.[/font][ul][*]A lot of people make the mistake of going too quickly, so the next bit is up to you.[ul][*]Over time, general cleaning and polishing it will flatten the paint and it will naturally blend well.[*]If you can't wait, start slowly.[ul][*]P2500 with soap water[*]Gently rub the raised paint, do not worry about dulling the original lacquer next to it, this grade is very fine.[*]Work in 3-5 second bursts, wash with water and review your progress. Get side on and look at the raised area.[*]You are looking for a slight raised area, then stop.[/ul][/ul][/ul][*][font="arial,helvetica,sans-serif"]Now you need to polish[/font][ul][*]Either use a electric polisher, or a fine cutting paste G3 etc...cutting paste is key![*]cut the final 1mm (or less) down.[*]Polish[/ul][/ul][font="arial,helvetica,sans-serif"]Generally if you have done a few chips in one area an electric polisher is worth the investment, you can buy a good one for £80-120, you do not need a deluxe profession system...[/font]
[font="arial,helvetica,sans-serif"]Your done![/font]
