Stone guards - bit of a long shot....
wolfie308
My trusty steed is at the menders again, this time for some cosmetic work including a welding repair to the bottom front nearside wing. My garage says I will probably have to loose/replace the stone guard and as I only had them all replaced a couple of years ago at about 60 quid a set, I'm loathe to spend the same again when I only need one piece.
So my question rather optimistically is - does anyone by any slim chance happen to have one or part set ?
Many thanks for that Catamax944, I don't check TIPEC that often and had missed that. I've mailed the vendor,so hopefully they're still available.
Surprise, surprise, they are in fact available separately - just ordered from OPC Exeter.......£9.19 + VAT
Rememeber - if in doubt, 'always check with OPC first'......I should know that by now![:)][:D]
I would not have posted with that info if it was not the case Wolfie, i have bought a few over the last few years in seperate sections.
Use soapy water in copius amounts to fit them........easy peezy !
