Storage / Disconnecting Battery?
- Thread starter roygarth
If you have a aftermarket alarm fitted this is usually wired across the battery, so it is not isolated by the factory fitted isolator, and you need to be careful as battery removal/disconnection rather than isolation will cause the alarm systems own internal rechargeable battery to eventually run down then it will go off !
