Storage of 944 S"
H823ENM
Hi
I'm having to travel abroad a lot and will now be away for around 8 months, can I get some advice on storage.
Martin
Umm, don't? [&:]
My previous car really suffered in storage, albeit 18 months. I had dried-out oil seals, tyre issues, handbrake cable and shoe problems, generally it was an unhappy car. I'd suggest, if you can, getting someone trustworthy to give it a really good run every week or so. The sort of use that many of the cars actually get now. Otherwise, it's at least worth jacking up to avoid flatspotting the tyres, putting a battery conditioner on and running the engine regularly to keep everything oiled and happy.
I guess if you must store it and can't get anyone to drive it while you're gone then as long as it is in a garage so is dry and you do a service before and after, make sure the coolant has a good concentration of anti-freeze in it and the brake fluid is reasonably fresh then there is not much else you can do! The worst thing you could do is to put a cover over it.
From my experience I'd say do something to stop the tyres from flat spotting. Either over inflate them or get someone to move it about, or put it up on axle stands.
Also make sure the interior is properly dry and keep the car in a dry garage if possible. Put a battery conditioner thing on it if possible, and do something to disable it (remove rotor arm or sometthing) to stop it getting nicked!
