1) A car cover will stop the dust gathering (I haven't got one myself - mainly I just polish and wax before storing so it hoses off easily!)
2) Make sure the tyre pressures are correct so you don't get any flat spots.
3) Connect the car to a battery conditioner so that you can start it at will. I use an Oxford Maximiser, although there are alternatives.
I've also carpetted my garage to minimise the rising damp from a cold concrete floor.
Other than doing that, I've never had any problems starting it after long periods (firmly touching wood at this point!)
Having been into concours classic cars a few years ago `how to overwinter your classic` was always a subject that arose at this time of year.
DONT use WD40 to protect steel, it dries out and water then attracts, believe me I know.
If you must use a cover then use one that wicks damp, a cotton type absorbs and holds water (as does a carpet) Most cars with older paint (despite what the manufacturers claim) dont like moisture between a cover and the paint. You dont cover it outside do you [
IMHO a carpet will hold moisture wheras a dry concrete floor will `give up` its moisture (if any).
Ensure
plenty of ventilation, I know that it lets in damp air but it equalises the dew point which prevents condensation forming. Note also that good ventilation will also dry out the space regularly too.
Use a battery `optimiser` NOT a charger
Clean off all bugs and bird poo
Wash and wax the car before putting it away
A smigeon of vaseline on the door seals stops them sticking (also works on your daily driver if its frosty/freezing) and wont ruin your best whistle.
Open up garage and car doors and windows on a nice dry day
Sticky (expensive) tyres will flat spot so jack the car off the ground or move car back and forth occasionally
Leave handbrake off
Cover or tape up the air intake, some valves will be open
A squirt of engine oil down the spark plug hole will coat the ring and help stop abrason when starting
When starting up after a long time, take off HT lead and turn over till oil pressure registers
Running the car at idle to warm up is supposed to be a no no, personally the only reason I can see is that it fills your exhaust up with water. I do it now and again but run it at fast idle and rev it much to the neighbours annoyance [
] Ensure it reaches max temp and use all switches, heater, wipers etc to esnsure they still work.
etc etc etc
Not that I do any of these any more (except the `optimiser`)
