All,
I indulged in the typical Sunday morning "spirited" drive this morning - to dry the brakes out after cleaning the drillings of dust deposits and the subsequent wash. All was well until, at about 6000rpm in 3rd, I heard a sound much like a stone hitting a wheel arch lining, shortly followed by the red exclaimation mark and fan belt warning light. Naturally I brought the car to a stop asap, and headed aft to take a look. The first thing I noticed was a dimple in the paint on the engine lid, clearly caused by a small projectile hitting the inside of the lid at very high speed. My next observation was that both belts to the engine fan appeared intact, and retained good tension. I was surprised to see that three blades of the fan, previously pristine, were damaged on their leading edges, as if flakes of the alloy had been chipped off. I assume it was one of these (tiny) flakes of metal that flew off and damaged the engine lid.
Has anyone heard of a problem like this before? I found myself wondering whether another flake could have caused an impact to the fan belt sensor to trigger the warning. Would the light illuminate otherwise if the belt is not broken? (I assume I am right in thinking that the belt in question is one of the concentrically driven belts attached to the main fan rotor, rather than a hidden belt? If I am correct then I can only guess that a stone must have somehow got into the engine bay and hit the fan when it was at high rpm. Obviously I have booked the car in to be checked out and repaired, but my belief that the belt is not to blame would seem to be supported in that the oil remained at typical temperatures while I coaxed the car back home.
Any experience and thoughts much appreciated as, being a relative newcomer to 993 ownership, my thoughts have inevitably turned to the potential for a substantial wallet-bashing! The car is a pre-varioram C2, having covered 80 thousand miles, and with an excellent service record.
Thanks!
Thanks!
