scam75
Well-known member
Hi Chaps
Had this problem since I got the car (about a year ago), doesn't seem to cause any problems but a bit concerning never the less. If I start my car from cold and let it idle you can hear an intermittent knock coming from near the distributor cap (could be inside the engine but definitely right at the dizzy end). It sounds like the arm clunking off the cap and if you play about with the cap whilst running the noise can come and go. There are no obvious signs of trauma to cap or arm however. Noise will go away when car heats up to first line on temp gauge or after a few revs. If you get in the car and drive it from cold you tend not to hear anything at all.
I have tried a different cap and arm and also replaced the gasket the cap sits on. All made no difference.
Has anybody experienced this before?
Stuart
Stuart
