strange noise
- Thread starter colin944
Now you didn't mention the abs light......... That's probs what it is although I would reckon you would be able to feel the abs working through the pedal when you touch the brake.Put your ear just below the side repeater indicator on the drivers side wing and you will be able to hear the abs pimp is it is running.ORIGINAL: markmsa yep checked the fluid level hot and cold and its fine, is the abs pump on this side could it be that as the warning light is on but I put that down to a sensor?
