Doncha just love a routine job that turns into a 4 figure nightmare?
Bought new pads and shoes for the rear wheels of my 98 carrera 2 cab and gave to my trusted mechanic to fit. Unfortunately, the caliper mounting bolts had fused into the hub carriers resulting in stripped threads. The outcome is 2 new hub carriers with discs, bearings etc (no point replacing old stuff since I track day the car) with a bill for parts alone hitting 4 figures. The lesson? Check your caliper mounting bolts (there's only 2 per side) and make sure you can get them out. Then copperslip the threads to prevent corrosion/fusion.
