strut housings for turbo on ebay
DC911SC
http://www.ebay.co.uk/itm/Porsche-944-Front-Strut-Housings-/191399487706?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c904c68da
there has been some suspension chat recently. I havent personally attempted this project I just bought new sealed units, but a few people were talking about it. For a £10 starting bid a bit of the work is done!
I just done this modification to my S2. Not a lot of work but these will save you making a mess in your garage as you only need swap over your springs, etc. I would caution anyone thinking of buying these that you don't know exactly how much of the top of the strut has been removed. As per the Koni instructions - you determine how much to remove from the original strut body DEPENDING ON THE INSERT YOU ARE INSTALLING. You actually measure the insert in hand and consult a table in the instructions to determine how much to cut off the old strut. I can't say that all 944 inserts are the same so you need to confirm that the remaining length of the strut tube is AT LEAST long enough for the insert you have to install.
