STRUT TOP MOUNTS
pal944
Hi can you change the top mounts by just undoing the 4 bolts and putting the new ones on or is threre more work involed thanks paul
Depends. In the standard setup the strut top is stopping the spring from popping out, so if you removed it you would need to remove the whole McPhearson strut, use spring compressors to remove the strut top. Aftermaket struts often have their own spring hat so the strut top bolts upto that. In that setup it is theoretically pheasible to remove the strut top without removing the whole strut. But a re-alignment would be necessary aftertwards - and you might get a difference in height if a different strut top is used.
