dave364634
won't start.
sommetimes it ill and it'll run fine till i turn it off.
so i'm guessing it's electrical.
the dme relay clicks when you pull it out/in (igg on).
i have put an immobiliser on it, but don't think it is that.
how do i get to check at the fuel pump?
is it in the tank, with an access point under the rear seats?
if it is an engine sensor (ie crank position sensor) how will i be able to tell?
what are other 'poientials'?
ta.
ta.
