Stupid Question Re 968 head
- Thread starter colin944
JamesO
The valve cover is even swappable (except the hole for the variocam solenoid)
ETA
The inlet manifold also fits both heads.
924nutter
JamesO
Neil Haughey
The inlet valves are loads bigger but the question is does one really want to rev the nuts of the S2 bottom end? I have been advised by them many times for example to be careful about revving the engine round past 6500 rpm as a lot of failures under racing conditions seem to involve lots of revs. On that special engine they would have used their custom all steel bottom end as seen on the website.
Neil Haughey
Ex Skyline
Indi9xx
Mechanically, using the 968 head, you could just bolt it on and suck it and see, but that could wind up with the chance of valve to piston collisions at high rpm.. in some cases it should all clear, but sods law will say a set of used springs, a slightly worn cam, s2 pistons and 968 valves may hit a anti-sweet-spot and result is a nasty mess...
968 and S2 cams do indeed have different sprockets
Indi9xx
I have always wanted to build an experimental 944 engine, not to be the biggest, or the baddest, but to build one to destructively test just how far the engine could be put on a diet and remain reliable, I am pretty sure the internals could be put on a diet and loose 30% of their considerable internal mass, as well as loosing about 40% from the clutch and flywheel weight, and still remain reliable... It might idle like a muscle car.. but it would pick up like a motorcycle engine and loose a massive amount of parasitic losses, add to that a dry sump, make it breathe and raise the rev limit and I think it would be an awesome engine.
But, I never get round to it.. I should.. Build that 968/S2 hybrid!
edh
