will lyons
Hi all
I thought I would share this experience with everyone
Yesterday I had my car booked in at a local new Independent Porsche specialist I also think they are worth including in this post here http://www.pecarspecialists.co.uk/html/home.html
When I bought the car last year I contacted the previous owner and was informed of the slight leak on the Sump dripping onto one of the heat deflectors causing a rather smoky oil burn for the first 5 mins then as the engine got hotter it either burnt away or sealed whichever was not a serious problem, however I purchased the Sump seal with intention to replace it when I could ... that day being yesterday.
A job not for the faint hearted I would be the first to admit especially with the involvement to complete it is a mamoth task indeed all the front suspension has to be disassembled, the engine supported on a beam from above and the front transom beam lowered to allow the sump to be coaxed away, then the exhaust removed from the turbo and wastegate section as the sump will not release due to it being so close to the top of the pipes.
Both the guys worked all day on my car and completed it in great time to an excellent standard replacing any coroded or damaged bolts etc as necessary while the sump was off a thorough inspection of the botttom end was carried out and even though the oil pick up was very clean that also was sprayed and wiped clean before the seal was replaced.
A new oil filter was fitted and without stating the obvious the oil was replaced. Both the guys are Porsche experienced technicians as I am sure they would tell you over any enquiry I have entrusted my car to them for all future servicing and work competetive pricing and more than excellent service is hard to find and I would like to say they are the new independent in the Yorkshire area!!
regretfully I did not take any photos during the work I really wish I had its not a very pleasant sight to see your 944 in pieces and the engine supported by a single chain from a cross beam.
If any work on your car is needed and they are within travelling distance give them a call even though the 944 is not in their pricing structure I am sure you will be accomodated as I have been .... A very happy customer well done Guys
