Sump plug problem
- Thread starter MKS
richardjjs1
Balance the cost of extreme damage against getting it done professionally
Even a Porsche Centre will only charge an hour - But you do need to get affixed price
Obtain a new Plug
I would certainly try a pair of WAter pump pliers May help if engine is warm.
Perhaps give it a sharp tap in the right direction with a hammer and chisel BUT ONLY ONCE
richardjjs1
Should be a quick cheap fix - Get them to loosen it and retighten and do the job at home
The simplest solution is usually the best
Del2171
