Hilux
Nice sunny day and the 951`s in auto2000 in Kempston since Friday
(sorry Andrew, I know I said I`d get it done at your place but I`m v v busy at the mo and work in London so I thought, what could go wrong - its only a sump swap after all so I`ll go to a local Porsche indy)
As you all may recall I got a s/h sump, cleaned it, tested the float etc and handed over expecting no real problems.
I`m told apparently the exhaust cross over pipe has to come off so bolts are now snapped off (I trust that this is in the exhaust and not the block? and have to be drilled out and rethreaded and apparently oil pipe seals are now required as its leaking oil? What oil pipes? Power steering? Are there pipes that have to be removed for to change the sump?
Can anyone elaborate please?
