Hi there, I have been working on the front headlamps of my s2 and have replaced the rubber boots on the bolt that determines the position of the headlamp unit when raised so that headlamp alinement is consistant, I cannot see any stop to determine the closed position. The n/s headlamp is a little lower than the body line and I cannot see how to adjust this, hope someone can help, John
sunken headlamp pod
- Thread starter pegasus
random hero
Inside the inner wing are 3 10mm bolts,loosen them off and lift the light into position required.
Diver944
The triangular mounts are highly adjustable. Once you have loosened them off you can twist the whole fulcrum so that the front of the pod is raised yet the rear of the pod stays still. It's a fiddly process and will involve lots of loosening and retightening until you get it right
ORIGINAL: pegasus
Thanks for that I'have a go at them over the weekend,thanks again,John.
Be careful with the bolts as they are really easy to strip the threads off.....
