Sunroof Advice please
robdimond
Easy... get two new gears from an OPC, then follow the Clarks Garage instructions to the letter. They are spot on!
Went to open the roof yesterday and one side is opening further than the other. I take it the grinding and popping noises its making are the dreaded sunroof gears. It's the driver side and I've not taken it apart to look yet , but how do you fix it ?
Surprisingly easy job to do, and you all know how I'm useless at any DIY. [&:] My only problem was the headlining all being brittle, and not easy to remove/refix. Pick the two cogs up from your local PC. It's worth a decent coffee. [;)]
ORIGINAL: zcacogp
ORIGINAL: pauljmcnulty Pick the two cogs up from your local PC. It's worth a decent coffee. [;)]
Thanks for the tip Paul. How do you get coffee out of your computer? Oli.
Poor it into the keyboard, swirl it around a bit and then decant.
Just done mine on the red 924S-as already said,follow Clarkes Garage-however,don't assume the current microswitch settings will be correct with the new gears in situ- you may find that the roof doesn't shut down as tight as you want-you need a handheld mirror,decent LED lamp to illuminate under & around the drive plate,also good hearing with little sound interference to hear the microswitches clicking.
ORIGINAL: zcacogp
Oli, you see, this is why you are currently banned! [:D][:D]
Ah, yes, thanks for reminding me! I'll update my signature accordingly. [;)] Oli.
Fitted a new pair of sunroof gears this afternoon £9 for the pair from Porsche Glasgow ( Thanks guys ) Roof is now working perfectly.
