danmason
Recently had an issue whereby some days my sunroof won't go up. Since this doesn't bother me particularly, I've just assumed it was something to do with the switch and figured I'll get around to it.
However, had a different behaviour today so it seems it's probably not the switch... I lowered the arms to remove the sunroof, and the first thing I noticed was that if I hold the switch down, the whirr of the motor continues indefinitely; pretty sure that was not always the case? Secondly, when then trying to raise the arms again, nothing happened... so although that's quite similar to what I already described above, I believe (from memory) the switch is operated the opposite way around for raising/lowering the arms.
So I don't know, given that this has been intermittent, if there are some connections I should be looking at, or a microswitch somewhere, or what... quite familiar with the 924 sunroof mechanism, but not this one.
Any thoughts?
Any thoughts?
