SUNROOF PROBLEM
Adrian888
The sunroof works ok except when closed it is not secure or locked in place. When driving at speed the roof is 'lifting' about 5-10mm. If i open it slightly (10-15mm) then it stays in place. Also when the doors are closed quickly the roof jumps with the air pressure. I assume this is nothing too serious and hope it is a 'DIY' repair. Any advice/assistance would be much apreciated. Apart from that and crap radio reception I am totally smitten with the car!
Sounds like the microswitches are out of adjustment and causing the arms to retract down into the roof instead of holding it shut. There is a good guide on sunroof setup in the 'Manual' section of [link=http://www.clarks-garage.com]www.clarks-garage.com[/link]
I have same problem and just close the roof so that it secures it. I would be intrested in any advice from anybody who has adjusted the switches please.
Exactly the same prob here too lads, my arms never stop in the locked position, go straight back into the roof [:D] I'm gonna print out the (daunting..?!) Clarkes Guide and go through everything when I get a day off. Also, my arms only ever move with the ignition fully on. Pretty sure they should only retract etc in position one.
Ps- check out my thread below, explains about radio reception/ power feed for aerial [link=http://www.porscheclubgbforum.com/fb.asp?m=433692]http://www.porscheclubgbforum.com/fb.asp?m=433692[/link]
Check the plastic gears have all of their teeth, mine did the same poped up while driving down the motorway, scared the living daylights out of me, after a little look one of the plastic gears inside was missing a load of teeth so it could move while shut if it was in the wrong place.
My problem occured when I replaced the plastic gears,I just need to set the microswitches up.[8|]
Hopefully will get chance to sort it this week given some fine weather. the streo is a replacement unit so suspect the fitter wasn't aware of the power supply issue, will look into that as suggested.
