I know this must be fairly common, but after a few years away from 911's, I can't recall the remedy. The power sunroof on my newly acquired 84 coupe no longer works, but I can hear the motor working; I know the zip in the rear of the headlining is for access to the workings but can anyone advise wqhat's probably wrong and how easy it is to cure. I am fairly capable mechanically, so can do most things.
Also, the clock doesn't work - replace? Fuse? Connection?
and drivers door window is very slooooooooow.
Any assiatance with advice on any of the above will be greatly appreciated.
