andymorris
I now have a problem with the sunroof.
In that I can only open and close it manually from inside the boot. I am guessing at this but woud presume there is some sort of mechanism inside the roof that is the problem. When this happened the "arms" got stuck inside and would not return out. There was also a judering noise. Does this ring any bells? Would it be easy to fix? And where should I look at getting the parts?
Any advice would be greatly appreciated.
I have gained a little confidence in trying to fix it myself having succesfully replaced the starter motor[
