Kongsodoken
so for some time the sunroof has not worked then it started working when I changed the ABS relay[:-]
so it moves from the locked position to the released position
it moves from the released position to the locked position
it will not raise passed the locked position
what I've done so far
swoped the relays over on the sunroof motor ...same effect so I'm guessing they are Ok
removed the roof and operated the microswitch this stops are starts the travel so guessing it!s Ok
fitted a new console switch
read the clarkes guide it does not cover this sinareo ....
my questions are ....would a faulty main relay cause this issue even though motor works in both direction
anyone got any ideas?
