Sunroof stopped working
gemmerson
Nice sunny day ( rare in Glasgie) and now the sunroofs not working. Checked the fuse which is OK, but when I press the switch there is no noise of motors or anything working. The Clarkes Garage web site seems to give everything apart from whats the most common reason when nothing works in the sunroof department. Does anyone know if there is something I should check first, a common fault maybe before I start to go over every micro switch ........
Try the microswitch at the front of the sunroof by the centre catch. If it 'thinks' you have the sunroof out then I think the whole system is disabled until it detects you have put the sunroof back in
What is the relay for the sunroof ?
The place where the relay/fuse sticker shows it should be is blanked on my car but the sunroof still works [8|]
Or is it related to cabs only ?
my 88 2.5 s has been through 2 relays in 2 years, every thing stopped and it started raining i love the uk weather.........
I assume the relay is in the back hatch ( 1991 S2 ) as the main fuse box in engine compartment has no relay where it says there should be............unless someones knicked it of course........my electrics seem to giving up, back light for the clock and the light in the engine compartment have all stopped working now.
the light under the engine bay, i thought that was just for show..........!!!!!!!! G21 i might be wrong!!!!!!!!
