Chaps,
My S2 has (as have all other 944's I believe) a wind deflector strip at the front of the sunroof. I can understand the point of it - to modify the flow of air over the front of the sunroof aperture when the roof itself is removed.
It seems that for a given speed, there is an 'ideal position' for this flap; too high and it is noisy in the car, too low and it drums. This 'ideal position' changes with the speed (I think that higher speeds necessitate lower angles). However, it is made of a plastic not unlike that of washing-up-bowls and cannot be made to stay in one position - it moves around a bit in the wind it is deflecting. It is easy enough to reach up and move it to a better position, but having managed a long and fast run recently (I banked - correctly - on the notion that all the local plod would have been engaged with the royal nuptials and flexed my right foot satisfyingly far into three figures) with the sunroof out, it became tiresome to keep on doing this.
Is this normal? Is there any solution? Or should I just put up with drumming/noise/constant adjustment, or lower my speed?
