asjasj
Closing the sunroof on my car a while back the wind deflector did not fold down properly when the sunroof approached. Looking at the little plastic 'arm' that holds the deflector up I found the loop at the top was broken and hence not properly attached to the deflector. The other side was OK but did find the 'hinge' looked suspect too.
Found the part numbers on PET and checked the prices online.....both less than £3 each. Needed a DME relay so ordered these at the same time from my local OPC.
As a bonus found the parts came in pairs so even better value. Replaced all the old parts with new ones just because I could. Easy to fit, just need a cross head screw driver and about 5-10 mins.
For info, parts numbers were -
911.564.127.00 (hinges)
911.564.123.00 (arms)
Rgds, Ade
Rgds, Ade
