SUNROOF
SECTOR
My sunroof has broken, the motor runs but the roof does not open. Presume a cable has broken.
Can anyone tell me where I can source info to repair this myself if possible.
Thank You
pelicanparts web site under sunroof repair. easy fix if yours is like mine undo the zip in headlining at back and remove the cover for the gears it will be able to be wound manually
This might be a quick fix if you are lucky like I was, when I bought my car I had the same problem.
Unzip the head lining and on mine one of the motor screws had come undone and fell onto seat, realigned the motor and drive sleeve, refit screw job done.
If it is not the screw then the plastic drive sleeve may have stripped inside. Would imagine it is fairly cheap from your OPC, the fix is pretty easy as above but remove both screws remove old drive sleeve and refit assembly.
