dereksharpuk
Has anyone noticed that the 997S really does need super unleaded petrol. My 996 ran fine on ordinary, but my 997S does not like it. OK, so the book says super unleaded, but it said the same for the 996
Steve - I can only comment on what facts I know, but yes I believe there is a Tesco product at 99RON which achieves some of this higher octane through the use of ethanol in the blend - this has limited availability. Ethanol is allowed in fuel up to 5% according to EU legislation. OEMs do not recommend it's use in Europe at greater than 5% content (ref ACEA Worldwide fuel charter). In the US ethanol can be found at up to 10% in gasoline and of course in Brazil 22% ethanol in gasoline is common place.
Being an oxygenate, ethanol based blends in general will disturb the air fuel ratio setting of older vehicles without a closed loop AFR control, and in addition there will be a small increase in fuel consumption due to the lower calorific value, but the key issue is to ensure that the vehicle fuel system is compatible with use of ethanol based blends. Typically common questions which arise are:
Corrosion resistance of fuel system to ethanol
Seal compatibility with ethanol blends
Water uptake with ethanol (Although at the 5% and less level there is no clear evidence of problems.)
Rgds
Craig
