Something to frighten the 911 boyz...
have done the SC conversion on my 5.4 and ironed out the niggles
like air leaks and sliping sc belt, she is now running really sweat
here are some dyno figures i came accross in the US
pretty impressive stuff...
bare in mind they run 91 octane fuel over there as well...
DynoJet Results
order of results :
Owner/Model Ground HP / Ground Torque - Flywheel HP / Flywheel TorqueMods note : Efficiency = 85% 5-Speed 80% Auto
Tim Murphy 88 S4 5-Speed 526 / 486 - 618 / 571 (Supercharged, Intercooled, Dastek, 30 lb injectors, belt slip cured)
Joe Fan 88 S4 5-Speed 500 / 436 - 588 / 513 (6.5L/Headers/Exhaust/Threshie Intake0
Paul Grabowski 87 S4 5-Speed 492 / 445 - 578 / 524 Tim Murphy Supercharger Kit, RMB
Mark Anderson 88 S4 5-Speed 485 / 434 - 571 / 511 6.4L/2600 Lbs/Extrude Honed/80 mm Throttle Body/Threshie Intake
Marcus Hutchinson 85 S Auto 480 / 520 - 600 / 650 F.A.S.T. Supercharged
Dyno Performance 97 Viper 6-Speed 476 / 476 - 560 / 560 K&N, Corsa Exhaust
Tim Murphy 88 S4 5-Speed 463 / 441 - 545 / 519 Supercharged, Intercooled, Dastek, 24 lb injectors
Devek White Car 88 S4 5-Speed 449 / 467 - 528 / 550 6.5L/Intake/Cam/Heads/DasTek/Headers/Exhaust
Mark Anderson 88 S4 5-Speed 436 / 434 - 513 / 511 6.4L/2600 Lbs/Extrude Honed/80 mm Throttle Body
Clay Zbar 87 S4 Auto 352 / 434 - 440 / 542 Nitrous (150 HP Jets)
Randy Page 87 S4 Auto 344 / 315 - 430 / 394 Supercharged, Intercooled, RR FPR, 30 lb, RMB, Cat Bypass
Mark Kibort 86-87 S4 5-Speed 335 / 334 - 394 / 393 "Holbert Car",#004,Devek Level II Headers,3.5 " Race Exhaust,Airbox Mod,No MAF Screen,RR FPR, 86 Clutch,2800 Lbs
DynoJet Results
order of results :
