Suspension#2
jboy356B
Hi, my 1993 C2 sits a bit low ( 10mm ) on the drivers side at the rear. Is this just tired springs? The car appears to be on its original springs & dampers ( who knows?).
John,
It's hard to tell on a basic description I'm afraid. Rear springs on 964s have a hard time because of so much weight being supported. There's no real reason why one side should suffer more than the other though, so without taking the springs off to compare the free length it's difficult to come to a conclusion. 10mm is within the scope of the height adjustments on the strut and it may be that it's just badly adjusted. Only with the car corner balanced could you tell if there was a major difference between sides.
Dave
One of the lads on Rennlist noticed his car was suddenly sitting lower on one side (exhaust tip looked like it had dropped) and found that the engine carrier had cracked. Might be worth having a look in your engine bay just in case.
Thanks Dave, I think it may just be tired springs. The car rides and handles well with no surprises.
I'll use it for this season & add another winter project to my list!
Hi Steve, engine carrier is OK, have recently replaced both rear engine mounts.
Thanks for the suggestion though.
