sawood12
I know i've already posted a couple of suspension queries on here before but i'm convinced mine has been tweaked by a previous owner. The problem is my car is running lower than standard judging by where the wheels sit in the wheel arches and several comments from other 944 owners and by comparing next to other S2's or Turbo's. I've had a good look around and the strut and springs definately look like OEM so I doubt very much any aftermarket upgrade kit has been installed. If my suspisions are right the person has gone to a reasonable amount of cost and effort since the rear of the car is sat as low as the front which means they have gone to the trouble of getting the torsion bars adjusted. My car wasn't specc'd with M030 from new but it could be possible that a previous owner fitted M030 front struts and either had the rear of the car lowered to suit or had the rear torsion bars replaced without replacing the front hubs or brakes.
Question - how can I tell if my springs and struts are std turbo items or if they've been modded or replaced with M030?? Is there a part number stamped anywhere? Can I count the number of coils in the spring?
If my struts and springs are std Turbo items then why/how is the car lower than std? I know springs can settle over time but not by that much surely?
Yours very confused,
