Suspension bushes
- Thread starter robwright
robwright
DavidL
So can anyone point me towards a pic/diagram showing where all the relevant bushes are for front and rear suspension. I hope this is something within my capabilities once I know where to look.
Question after that seems to be what to replace them with? Polybush? Powerflex (or are these the same thing?)
chrisg
Super_Marv
So long as the ARBs are free to rotate around the bushes, then there's not really that much to be gained by using polybushes on the ARBs. Of course, they'll last longer and aren't ruined by powersteering fluid, but I've found the Powerflex bushes fitted to the outer ARB droplinks on my car are too tight a fit on the bar, which causes too much stiction and pre-load on the bar (the other Powerflex bushes for the ARBs are fine though, IME)ORIGINAL: zcacogp Purely from thought (and not experience of playing around with them), I can't quite understand why the ARB bushes are so critical. I understand what ARB's do, and hence why they need to be connected firmly to both the suspension member and the body, but I would have thought that slight compliance in these bushes isn't that much of a big deal. What is much more critical (in my understanding) is keeping the wheels running in the right plane and direction, and this is controlled by the suspension component mount bushes. I'd have thought that uprating these would make much more difference than uprating the ARB mount bushes. (NOTE: this is all the spoutings of an inexperienced man, and shouldn't be given any authoritive weight at all. I may well be - and probably am - wrong.) Oli.
