Suspension "clunk"
TTM
Well-known member
'evening everybody,
A couple of months ago some clunking noise in the front right suspension area developed on the S2.
At 110k miles I figured things down there were beginning to get pretty loose so I took on refreshing/replacing progressively most of the usual suspects :
Step 1 - Caster mounts replaced with 968 units
Step 2 - Rebuilt ball joints + switched back from the 30mm ARB to the original one, with all 8 new bushings (4 for the bar itself plus 4 for wishbone droplinks).
Step 3 - Upper strut mounts replaced today with solid units (Uniball)
I did test drives between any of the three steps mentioned above, and none had effect on this noise, which can be heard inconsistently :
- when driving too quickly on speed bumps. In this case the car feels like caster mounts are too loose, same feeling as with old worn out 944 caster mounts.
- when driving at speed over light bumps or potholes. In this case the car feels like the upper strut mount are loose to a point the piston of the shock hits the bonnet.
- when steering at nearly full lock (low speed manoeuvres). In this case the steering feels as if a spring that is not well seated switches back to its correct position. I checked this repeatedly and springs actually do not move one bit.
Next step is to replace the right caster mount with an old one to see if it makes any difference, but I doubt it - has there been cases of defective caster mounts ?
I am running out of ideas and feedback would be much appreciated.
Thanks.
You should expect some noise from your solid top mounts but clearly you had these noised before you installed them. Have you checked that the first 30 degrees or so of your spring has not snapped off? Sounds simple but I had a similar noise occuring at similar times on a previous car and I could not track it down nor could several garages I took it to. In the end it was found by the garage I use for MOT's.
Is your steering rack worn? If the bushes in either end where the shaft slides in and out, are worn, it can allow vertical movement of the shaft and corresponding noise.
Having read that back, it sounds so so wrong.....[:D]
What bothers me is not quite the noise itself but the inability to find an exact procedure to reproduce it at will.
I will have to find a pit and look from below to figure out properly what is going on when steering ...
ORIGINAL: sawood12
"Snapped off" ?
Not sure what you mean but I checked both springs and they are not broken.
What I meant was the bottom 30 degs or so of the spring that sits on the perch. You cannot see it due to it being inside the perch 'cup' so need to get your fingers in there to have a feel around for the loose bit of the spring, but even then it can jam itself periodically. I'm not suggesting it is a common problem - far from it, but it can happen and it also happened to a mate of mine's Boxster. Just a long shot but something to check out.
Replaced the spring! I just thought i'd mention it as your symptoms sound similar but sounds like you've checked it out anyway.
Problem solved. The bolts on the C-clamps holding ARB bushes onto the droplinks were loose.
Not sure how that happened as I always tighten them pretty tight, at least as tight as what's written in the WM.
So I ended up tightening them as tight as I'm stupid which means they are unlikely to ever loosen again. [:)]
