Suspension differences left to right
- Thread starter nfearn
Measure from the torions tube to the floor and see what the difference is then.
Black80XSA
Some people seem to try and set their ride height via wheelarch measurements when adjusting the rear on the eccentrics, and the front on M030 cars. God knows what sort of mess the heights will be in after that!
ORIGINAL: richthomas
It would look right though [
When I used to set up the Westfield this was always done with the driver in - but then my bulk represented a reasonable percentage of the overall weight. With a 944 the weight of the driver isn't as great in the overall scheme of things. While one accepts that there will always be a driver, if you were making allowance for passenger loads should you set it up with or without a passenger?
We seem to spend most of our time turning right - roundabouts, track days etc. So harder on the left might be better (would also allow for a passenger) But, if you were by yourself, and turning left, the offset centre of gravity due to driver only and softer right hand side would be far more unpleasant.
Having argued from both sides, I would be inclined to set up and measure with weight in for driver only.
