Suspension Geometry
- Thread starter calisa
85K miles now on original suspension too.
Keep it simple, Porsche Engineers spent a long time getting it right.
For road use, stick to factory settings.997.1 C4S
Just had shocks replaced and suspension checked over and about to get a 4-wheel alignment and set up.
Does anyone have recommended suspension settings to use/compare to the factory recommendations?
standard height, road use only
OEM it is!
new shocks (Bilstein OEM equivalent), all bushes checked (all are OK), one tie rod end replaced, new tyres fitted and pressures checked (I've got a small compressor so tyre pressures are checked regularly)
Added bonus was getting access to see if there was corrosion or other problems. All good so its now time to turn hydrocarbons into smiles
