suspension - KW3's or OE
- Thread starter silver7
zub
paul howells
Best advantage for adjustables is in the wet,as long as you know what you are doing.
Richard Dawson
Worth knowing as that is somewhat cheaper than Porsche charge for a new one.
sawood12
I've become a huge KW fan since installing it on my car. It is a stiff setup but is easily bearable on road. It has simply transformed the ride and handling on my car. The fact they are adjustable is inconsequential. I've just used the settings that the installers set and have left it at that. It is not as if i'm paying any more for that adjustability compared to the offerings from other brands (which is the case here is seems).
micksummer
Just did 2 days at the Ring, and 2 days at Spa with the new shoocks.
The car handled much much better with the KW, it's set up pretty hard for track use but it rides bumpy road way better. The old shock was checked and was found to be still servicable. It's being tested properly now so I get a certificate saying how servicably they are. I can then either keep them or sell them.
I can tell you for sure that the kw is a far far superior shocks!
micksummer
From the difference in handling I was expecting the old shock to be completely gone, so was quite surprised to know that they're still "sevicable", whatever that might mean. Will let you know what the test results are.
sawood12
ORIGINAL: ChrisW
But have you compare the KW's to new standard shocks with an equivalent set-up ?
Old shocks get stiff, and won't ride the bumps in extremis.
We all know that a stiff car should still be supple if it' going to stay connected to the road --- and it's driver
KW has a bypass valving mechanism internally in the shock. The shock is stiff and remains stiff for undulations, cornering forces and low frequency bumps, but for higher frequency bumps, like trackside kerbing or potholes on the road, then the bypass valve opens and the shock becomes less stiff. It is a sort of 'dumb' passive PASM. This allows KW to use stiffer springs without it compromising ride quality or performance. This is the key technology that KW has which i'm not sure if other manufactures use - well not the mainstream ones at least.
I would be willing to bet that KW's will be substantially superior to a fresh OE setup. They are very popular in the 996 GT3 scene so you are talking about people replacing pretty fresh shocks with KW's and noticing a difference. It will be stiffer with a more comforable ride. Great for drivng to the track, hacking round the track and driving back again.
Also the struts are made from stainless steel so no corrosion problems.
micksummer
ORIGINAL: silver7
thanks Mick decisions, decisions......Did you have the sport KW's?
Would love to hear from anyone that has had new OE suspension fitted to see what difference that makes.
yes I went for the clubsport version, which is meant to be stiffer. TBH it's pretty composed on the road, and actually more comfortable than the old half worn OEM shocks. The only way I can describe it is the car feels more "creamy" on the road!
micksummer
ORIGINAL: silver7
you are convincing me Mick! What are the downsides?
cost, non-OEM, other than that, I haven't found any.
The slow speed bump setting adjustment screw is quite tricky to get to, at the bottom of the strut, easier when wheel is removed. The rebound setting can be adjusted quite easily as the access is from top of strut, even the rear ones are pretty accessaible (might get quite hot with the engine heat but I managed in Spa with long sleeves).
