steveoz32
New springs on, everything cleaned, bearings sorted, ride height good!
30mm springs from PorscheShop dropped the car about 25mm from where I was, so exactly what I wanted
Car seems to be sat even now, aprox 22mm clearance from the height of the centre of the tyre to the edge of the arch in the centre down from mid 40's.
Only one small issue, since fitting these springs I have a squeek on the front drivers, what a pain in the arse. I've taken it apart twice, seems to be coming from the top of the mount near the bump stop, but only the drivers side is affected. When I sorted the bearings out, I cleaned all the rubber mounts with soapy water to get the gunk off, thinking this one got a little dried out. Took it to a friends garage and got it up in the air and lubed it all up, so fingers crossed this will sort it after a few miles.
Ride quality seems to have improved - not as harsh in a straight line on normal roads as the stock set up. Around corners it rolls a little then settles and seems to dig in.
Spacers next and then I'll be getting the geo checked, fingers crossed!
Roll on delivery of my PU GT3 front bumper
Can't wait to get that sprayed and fitted, along with the spacers it should be coming together nicely [
] Pics will follow.....
Cheers,
Steve
Cheers,
Steve
